Is there a package which will let you do a front-end menu, with a choice of buttons, and to be able to place them were you want. I know MGI Video wave does it. But, although you can do chapters, you cannot see them on them when you play the DVD. Easy CD 6 lets you choose the chapter button is static and square. Any help please. All this just to impress the family![]()
Results 1 to 9 of 9
There's lots to try. Depends on your budget, how flexible you want it to be, etc., etc.
Have a look at Tools -> DVD Author here https://www.videohelp.com/tools?listall=1#DVD%20AuthorThere's no place like 127.0.0.1
The Rogue Pixel: Pixels are like elephants. Every once in a while one of them will go nuts. -
That is the catch right there, most DVD authoring programs that don't cost alot of money will not let you place them anywhere. Text is another story.Originally Posted by superwow
Well, at least I don't know of any
"A beginning is the time for taking the most delicate care that the balances are correct."
- Frank Herbert, Dune -
Least expensive with greatest flexibility might be DVDLab - BUT could be a steeper learning curve for some.
Easy to use and flexible is Ulead DVD Workshop, BUT for ~ 3x the price of DVDlab.
I use both, depending on the project.There's no place like 127.0.0.1
I use tmpgenc dvd author can't move the buttons but it will allow animated thumbs
The Newest version lets you move things around and create your own layouts.hardcoreruss Posted: Sep 04, 2003 04:29
I use tmpgenc dvd author can't move the buttons but it will allow animated thumbs------------------------------------------------
Phillip
www.allaboutduncan.com
"Oh, they have the Internet on computers now."
Main menu/chapters/audio etc all on one motion menu in Encore. Possible?
By Killer3737 in forum Authoring (Blu-ray)Replies: 10Last Post: 11th Feb 2012, 13:08 -
DVD with chapters already I only want to make a menu while retaining all...
By dbbarney in forum Authoring (DVD)Replies: 6Last Post: 4th Oct 2010, 12:05 -
Produce DVD with chapters, menu etc
By tempsc in forum Newbie / General discussionsReplies: 2Last Post: 21st Apr 2008, 09:10 -
Sound on Background menu but not on DVD chapters....?
By tikigod19 in forum Authoring (DVD)Replies: 10Last Post: 3rd Aug 2007, 19:14 -
DVD with no menu and just chapters
By marshyman in forum Newbie / General discussionsReplies: 3Last Post: 8th Jun 2007, 17:36
